A digital multi meter tends to run all over the place when doing something like this.
An analog meter wher the needle just swings is the easiest to read in this case. Actually, any continuity tester will work, provided the coil is disconnected from the points prior to checking the timing.
Then don't forget to reconnect the coil after setting the timing!!
Jim
