Re: MotorCycle Air Filters On Mopeds?
Mbartell /
That looks like tha same carb as on my kinetic/vespa- kind of. Didn't a lot of people tell you to cut out a piece of filter that fits inside that large circle---
What I'd do is get a hose clamp that is the right size for the outer diameter, and get a piece of filter foam that is bigger than the outer circle.
Lay the foam flat against the big circle, and push your hose clamp over it. That would fit, if you didn't tear the foam, and it should work, without messing with the choke lever. Matter of fact I think I 'll try it with my vespa/kinetic--It just barely hit 30mph today.
You could use a lawn-boy filter at the hardware store- I think it's just a big square of foam, and it's pre-oiled.
The problem with putting a K&N filter on a bike like that is that it would stick out at least 3" and probably hit your front fender- unless you could find a pancake filter for it.
  MotorCycle Air Filters On Mopeds?Topic by: David Lawson David Lawson 07/30/02 09:51PM
  Re: MotorCycle Air Filters On Mopeds?Re: Fred Fred 07/30/02 10:29PM
  Re: MotorCycle Air Filters On Mopeds?Re: faust faust 07/31/02 04:59PM
  Re: MotorCycle Air Filters On Mopeds?Re: Mbartell Mbartell 07/31/02 05:36PM
  Re: MotorCycle Air Filters On Mopeds?Re: Jim A. Jim A. 07/31/02 08:11PM
  Re: MotorCycle Air Filters On Mopeds?Re: faust faust 08/01/02 12:38PM
  Re: MotorCycle Air Filters On Mopeds?Re: Andy Andy 08/01/02 01:29AM
  Re: MotorCycle Air Filters On Mopeds?Re: faust faust 08/01/02 12:40PM
  Re: MotorCycle Air Filters On Mopeds?Re: Andy Andy 08/01/02 12:45PM
  Re: MotorCycle Air Filters On Mopeds?Re: faust faust 08/01/02 12:58PM
  Just ordered a UNIRe: Mbartell Mbartell 08/01/02 01:04PM
  Re: Just ordered a UNI - FredRe: Mbartell Mbartell 08/08/02 06:50PM
  Oiling a UNIRe: Fred Fred 08/08/02 08:45PM
  Re: MotorCycle Air Filters On Mopeds?Re: David Lawson David Lawson 08/01/02 11:00PM
  Re: MotorCycle Air Filters On Mopeds?Re: Mbartell Mbartell 08/02/02 10:26AM
  Re: MotorCycle Air Filters On Mopeds?Re: faust faust 08/03/02 01:30AM
  Re: MotorCycle Air Filters On Mopeds?Re: Andy Andy 08/04/02 02:21PM
  Re: MotorCycle Air Filters On Mopeds?Re: faust faust 08/05/02 01:51PM
  Re: MotorCycle Air Filters On Mopeds?Re: Andy Andy 08/05/02 05:09PM
  Re: MotorCycle Air Filters On Mopeds?Re: faust faust 08/05/02 05:27PM
  Re: Oiling a UNIRe: Mbartell Mbartell 08/09/02 11:17AM
