Ignition Switch
AvoidingWork /
1991 TOMOS Golden Bullet TT-LX A3 50
Took apart the engine stop switch last night.
Been having a bit of a hard time starting it.
Presumed it was just because I don't know what I am doing yet.
But, then noticed that the headlight wasn't working and when I pushed the wire tight into the engine stop switch casing it would work.
Found a bit of corosion around one of the wires. Perhaps its just the way it was sodered for a solid connection.
Ends of the wires looked a little frayed and not tight around the screws. And, the tiny little blue piece of metal that contacts with the screw to make an on/off connection didn't seem like it was making a super tight connection.
Sprayed some wd-40 to remove the corosion.
Is there a better setup for this switch?
If I mess with the wires I assume I am going to have to solder the wire connections back together?
Just curious.
  Ignition SwitchTopic by: AvoidingWork AvoidingWork 07/30/02 09:12AM
  Re: Ignition SwitchRe: Reeperette Reeperette 07/30/02 03:16PM
  Stop/Start SwitchRe: AvoidingWork AvoidingWork 07/31/02 09:49AM
  Stop/Start SwitchRe: Procrastinating Again Procrastinating Again 07/31/02 09:50AM
  Re: Ignition SwitchRe: Procrastinating Again too Procrastinating Again too 07/31/02 02:13PM
  Re: Ignition SwitchRe: Reeperette Reeperette 07/31/02 03:46PM
