Motobecane Engine Problem....
My '77 Motobecane 50L is smoking like a cheap cigar and the plugs are fouling out with black soot. The bike is running very rough now. I am using the correct gas/oil misture ratio, so I was wondering what else could be causing these symptoms. Could bad rings cause my engine to smoke (oil getting past the rings)? Anything else I should be checking?
TIA,
Larry
Re: Motobecane Engine Problem....
What fuel to oil mixture are you using? It should be 50:1 (2.5once/1gal).
simon
Simon,
How come the gas tank says 4oz oil per gallon if gas? That is what I've been using.
Thanks,
Larry
If it's an old bike, probably from when they had leaded gas and sh!%%y oil. try 40:1 (3 oz to 1 gal) with a good, brand name oil. if it smokes less, run it and maybe lean it out to 50;1. may mean 4 oz to one tankful...
