tomos targa
mike /
whenever i put transmision fluid in my moped it leaks out through the center case seal all over the ground. i was wondering if i really had to take the whole engine apart to get at the seal; or can i spray some sort of HI tac in there and have it plug up the hole. i looked at where it is leaking and there is a big chunk taken out of the seal which is causing this to happen. and btw when i turn on my turn signals the light that indicates they are on only works when i turn on the left turn signal. i only have the back two on there is that the problem or is it something else. and also when i put my hi beams on the indicator dosent light. the bulb is fine and everything is hooked up right i think. well any answers?
-mike
  tomos targaTopic by: mike mike 12/07/00 09:30AM
  RE: tomos targaRe: Reeperette Reeperette 12/08/00 12:54PM
  RE: tomos targaRe: mike mike 12/08/00 11:16PM
  RE: tomos targaRe: Ron Brown Ron Brown 12/09/00 01:02PM
