Backfire
I found out a way to make my moped backfire on perpus, but I was wondering if it ruined your moped in anyway.
-Viet
Re: Backfire
how did you do it because i dont think that they are supposted to do that ... you might have something wrong with yous if you can just make it backfire
Re: Backfire
if u mean by flipping the kill switch on and off real fast i can do that too. I dont know if its bad for it but i dont know if its good for it ither....
Re: Backfire
Well, it could blow off your exhaust, bend the rod, bust a piston, or split the crank case.... other than those few things listed as very likely..... have fun! BANG! Doug D.
Re: Backfire
Backfiring occurs when unburned fuel mixture gets past the exhaust port and detonates (AKA "explodes") in the exhaust system instead of burning in a controlled manner within the cylinder.
Given that, do you still need to ask this question? Would you put an M-80 up your exhaust pipe?
By the way, what is a "perpus?"
Re: Backfire
Sorry for my misspelling, I always mean to use the spell check, but I forget sometimes...
I meant to spell purpose.
-Viet
Re: Backfire
thought you meant a dolphin or something.. j/k
im have no room to talk im barely learned myself. haha
can't type spell or speak correctly much less do all three
on this post...
Re: Backfire
Paul Brassington /
how did u make it back fire
