Puch Questions !
I rebuilt a old BOMBARDIER/PUCH MAXI 1976 one speed.
I'm going to change the transmission oil, it is ATF or DEXTRON3 i put inside ???
I remove the magneto and the strator to clean it all.
I check all the wires, the lights work but i didn't have spark at the plug !
Do you think is the POINTS or the COIL ?
The coil is inside the magneto !!!!?????
Thank's!
Re: Puch Questions !
the coil is the black box at the end of the spark wire. make sure your points are opening and closin. the transmission is filled with type f transmission fluid
Use Dextron 3 for the transmission fluid.
Type F
Type F tranny fluid.
Re: Type F
yes, use type f. Dextron is abrasive and isn't good for the clutch pads.
