Re: Big bore qeustion
XBrandon EdgeX /
I would imagine that the magnum is heavier than a maxi, so I'd go with a maxi. Maxi parts will work on a magnum, as long as you get a maxi cylinder or aftermarket big bore cylinder. The crancase/transmission part is all the same (exept for the oil injection on two speed magnums.) The magnum's stock cylinder has an angled exhaust port, so aftermarket maxi exhaust systems won't bolt up. For a stock bike, a Magnum MKII is probably the fastest (MKII's are two speed bikes.)
  Big bore qeustionTopic by: peashooter peashooter 07/24/02 10:28PM
  Re: Big bore qeustionRe: dave dave 07/24/02 10:50PM
  Re: Big bore qeustionRe: Kevin Harrell Kevin Harrell 07/24/02 11:17PM
  Re: Big bore qeustionRe: Toehead Toehead 07/24/02 11:35PM
  Re: Big bore qeustionRe: XBrandon EdgeX XBrandon EdgeX 07/24/02 11:50PM
