changing tomos transmission cover- how?
Joel /
On My tomos ttlx there is the right side aluminum transmission cover , on the side it has been ground away through about 3 millimeters of the case because the pedal arm used to be bent, and although still sealed, the metal is very thin. Also the transmission fluid drain plug is so stripped it stays in by a very small amount of threading... I have a parts bike to get a new case off of, i just need to know how hard it will be to do this. I just put a new front fork on it and it took like 3 hours! I need to know if there is anything really important to look out for when doing this. I just know that last time i replaced something big, it took way longer than i had expected. Replies appreciated.
