RE: Bi Turbo is Too LOUD!
tim /
the biturbo is actually very quite if it is tightend to the engine properly. I had the same problem you do with the wrench fitting. you may not want to do this, but i removed the exhaust studs, and used allen bolts to hold the pipe in place, that way you can tighten it with getting the wrench in the way. however, they did come loose every month or so, so you might want to use lock-tight or something
  Bi Turbo is Too LOUD!Topic by: Ataristyle Ataristyle 12/01/00 12:50AM
  RE: Bi Turbo is Too LOUD!Re: tim tim 12/01/00 12:56AM
  RE: Bi Turbo is Too LOUD!Re: tim tim 12/01/00 01:00AM
  RE: Bi Turbo is Too LOUD!Re: Ataristyle Ataristyle 12/01/00 01:43AM
