question about 15mm bing carb....polini kit
chuck russo va /
i raised the needle thing in the carb and put a 90 jet in my 15mm bing for the polini kit so it was on the richest setting like i was told
the kit wont run, if i pedal for an hour it will spudder and then die when u stop pedaling after like 2 or 3 seconds
cleaned carb, has spark and fuel flow
the choke plate kinda hangs in the carb like 1/8th inch or so.... is this normal? or is this from changing the needle position?
has new plug in it also
