MAKE IT FASTER
hey i just bought a honda urban express 83 it sounds fast but when i rev it on the stand it screams when i sit on it and give it throttle it dies out .Then i cheked the fuel valve its pouring gas out is this carbeurator problems.Any ideas appreciated.
Ev jAy
RE: MAKE IT FASTER
Ron Brown /
Ev,
Most likely, if you have a manual choke see if playing with that helps. It is possible for the ignition to cause those symptoms but not unlikely.
If it has been sitting a while, clean out the carb, clean and gap the points, check the spark plug etc.
Ron
RE: MAKE IT FASTER
try lowering the idle, may be to fast and letting in to much gas, which will pour out with nowhere else to go but out.
