RE: cold air = lean?
Ron Brown /
Nick,
Cold air = rich, I think, because high altitude = lean.
You do not mention the temperature, but the most likely problem is condensation or icing in the carburetor caused by the additional cooling effect of gas evaporation. Standing still allows engine heat to warm the carb.
If you can rig it, some cars get around this problem by directing warm air from the exhaust manifold to the air intake. I imagine that the cylinder fins would also be warm enough. You may even be able to fashion an air funnel around the carb to warm up the outside of the carb with engine heat.
Good luck,
Ron
  cold air = lean?Topic by: Nick Nick 11/29/00 12:52PM
  RE: cold air = lean?Re: Ron Brown Ron Brown 11/29/00 01:17PM
  RE: cold air = lean?Re: Ivo Ivo 11/29/00 05:27PM
  RE: cold air = lean?Re: mike mike 11/29/00 09:08PM
  RE: cold air = lean?Re: Fred Fred 11/30/00 02:22AM
  RE: cold air = lean?Re: Ron Brown Ron Brown 11/30/00 11:02AM
  RE: cold air = lean?Re: Ivo Ivo 11/30/00 04:03PM
  RE: cold air = lean?Re: Fred Fred 11/30/00 05:55PM
  RE: cold air = lean?Re: Ron Brown Ron Brown 11/30/00 05:57PM
  RE: cold air = lean?Re: Fred Fred 11/30/00 06:36PM
  RE: cold air = lean?Re: mike mike 11/30/00 07:29PM
  RE: cold air = lean?Re: Fred Fred 12/01/00 03:50AM
  RE: cold air = lean?Re: Ivo Ivo 12/03/00 06:40AM
  RE: cold air = lean?Re: mike mike 12/07/00 09:22AM
  RE: cold air = lean?Re: Ron Brown Ron Brown 11/30/00 07:48PM
  jettingRe: Fred Fred 12/01/00 02:27PM
  RE: jettingRe: Ron Brown Ron Brown 12/01/00 04:59PM
  RE: cold air = lean?Re: tim tim 11/30/00 11:00PM
