RE: break in period does exactly what?
Ron Brown /
Joel,
Read my post again, slowly and carefully.
I sugested NOT using synthetic for the run-in period.
I also described galling of metal and siezing as possible results of not running in correctly. Some would describe this as "blowing the piston" I suppose.
In addition, when you first get it running, warm it up then ride it for a minute or two, then check the spark plug for a light brown color. If the color is any lighter than that, don't ride until you increase the main jet, a lean mixture will make the engine run hot enough to seize and/or hole the piston.
Ron
  speed kits- is 60cc safer?Topic by: Joel Joel 11/29/00 12:16PM
  RE: speed kits- is 60cc safer?Re: tim tim 11/29/00 09:26PM
  RE: speed kits- is 60cc safer?Re: Joel Joel 11/29/00 11:57PM
  RE: speed kits- is 60cc safer?Re: tim tim 11/30/00 10:24PM
  RE: speed kits- is 60cc safer?Re: Joel Joel 12/01/00 12:38AM
  RE: speed kits- is 60cc safer?Re: tim tim 12/02/00 01:00AM
  break in period does exactly what?Re: Joel Joel 12/04/00 12:36PM
  RE: break in period does exactly what?Re: Ron Brown Ron Brown 12/04/00 03:46PM
  RE: break in period does exactly what?Re: Joel Joel 12/04/00 11:32PM
  RE: break in period does exactly what?Re: Ron Brown Ron Brown 12/05/00 10:12AM
  RE: break in period does exactly what?Re: Ian Ian 12/05/00 12:39PM
  RE: speed kits- is 60cc safer?Re: Joel Joel 12/05/00 11:31PM
  RE: Installation 60/70cckitsRe: Armando Armando 12/29/00 09:22PM
