recently i took off the rear fender on my tomos and the hollow tube that goes through the frame that both shocks bolt to had a very slight u shaped bend it it. I can prevent that from bending any more by finding a piece of metal the right size and put it in the middle of the tube (it's hollow) but i also want to treat the problemby what's causing it...the tomos shocks have so little travel, I need shocks that are taller by about an inch and have softer springs and are oil filled. The suspension arm swivels downward enough to accomodate bigger shocks. I also want some tires for riding on trails, not really rough trails, but tires with quite a bit more "grab" than the typical tomos street tires. i mainly ride gravel covered trails in the woods near my nighborhood. also does anyone know how to make the tomos brakes stronger? I have put a larger brake cable on the rear, but i do not know if these are readily available anywhere. i found it on a junk moped. The cables i got on the bike were bicycle cables and they both snapped. And i'm getting a speed kit soon , i need to have a thick cable on the front too. anyone know where to get big cables for cheap?
swarm, destroy
