Is this exhaust any good for on my Peugeot 103 mvl 1988 sha 15:15
Not worth it if you’re still at stock displacement. In fact you may not be able to mount it without modification anyway. It’s a nice exhaust otherwise.
I friggin love this pipe! I run it on my "stock" 103, now Im running a stock late model Euro cylinder, so it has the bolt on style exhaust, this wont work with the US screw in type.
Im a huge fan of this pipe, wish we could get a few more state side, good luck!
Wth do you mean? I don’t get your point ? My setup is polini reed and intake and sha 15:15 .
Polini reeds, and a Sha doesn't define what kind of exhaust port your cylinder uses.
Ya, you have the screw in style, so this exhaust wont work for you.
To put it another way: this exhaust uses two bolts to screw into the cylinder, the cylinder you have uses one big screw nut around the exhaust pipe to screw into the cylinder. This is for a different style cylinder, and therefore won't work with the one you have
Will the Doppler er1 fit?
