"I had a great-running 1980 Peugeot 103 SP moped...that is until it stopped producing a spark. I tested the electrical system, and everything seems fine (the lights, horn, brake lights, tail all work) but there is no electricity getting from the magneto to the coil. I took the points out and cleaned and filed them, all to no avail. I inspected the wiring coming from the magneto and it looks fine. I have no idea how to take apart the magneto because the flywheel seems permanently fastened to the crankshaft. If anyone can give me any suggestions on how to get my ped running again, please reply!"
Peugeot 103 with no spark
Re: Peugeot 103 with no spark
Bang on it with a hammer!!!<br>
: Bang on it with a hammer!!!<p>Tried this and it's not coming off. Is there anyplace special you must hit it? Do you have to pull on it whild banging it? I've never taken one of these off before.<p><br>
": I had a great-running 1980 Peugeot 103 SP moped...that is until it stopped producing a spark. I tested the electrical system, and everything seems fine (the lights, horn, brake lights, tail all work) but there is no electricity getting from the magneto"
": : I had a great-running 1980 Peugeot 103 SP moped...that is until it stopped producing a spark. I tested the electrical system, and everything seems fine (the lights, horn, brake lights, tail all work) but there is no electricity getting from the magne"
"<br>: : I had a great-running 1980 Peugeot 103 SP moped...that is until it stopped producing a spark. I tested the electrical system, and everything seems fine (the lights, horn, brake lights, tail all work) but there is no electricity getting from the m"
": : Bang on it with a hammer!!!<p>: Tried this and it's not coming off. Is there anyplace special you must hit it? Do you have to pull on it whild banging it? I've never taken one of these off before.<p>Dont Bang on it with a hammer, in most cases the reason a flywheel isnt coming of is because you need to apply equal force on opposite sides of the wheel, try putting like a solid screwdriver on both sides and pull really hard and it should pop right off, I had the same problem, then by accident I tried both sides equaly out of frustration an VIOLA!!!!<br>"
did you find the solution to your problem?
i have a peugeot with the same isues no spark
i test the wires from the magneto and all light up
but when i connect to the ignition coil no juice at all
help ???
Maybe I've been trolled, but if not do you realize this thread is 13 years old?
