> Satan 666 wrote:
> > campeona del mundo wrote:
> > they make fogging oil for this reason. remove plug, get piston to bdc,
> > blast with fogger oil crap
> I worked in an outboard shop and when I winterized the 40 plus engines
> from 2 to 25hp after I changed all the oils, tuned up and made sure they
> ran well I would always run Lucas upper cylinder lube, Startron
> stabilizer in the tanks they came in and always blasted Fogg oil in them
> until they started to bog out and toss them on the storage rack. This is
> just what a factory trained tech would do I guess? In the spring just
> toss em back in the tank and run until the oil was gone and give back to
> the customer.
Ya I did similar winterizer stuffs to larger 2 to 8 cylinder outboard motorboats at a marina with fog oil, stabilizer etc and at a farm to snowmobiles and snow plowing equipment.
So fogging, gas stabilizer ect. is good for long periods of time, most 2 stroke premix oil has some stabilizer in it so it’s good for shorter times of not use.
