Re: Smallest part you've added...
James P /
> Terbo Speghetti wrote:
> > James P wrote:
> > Deleting a head gasket does lower compression when you more than make
> up
> > for it with a thicker base shim.
> It lowers compression in the bottom end, yes. But raises it in the top
> end.
No it does not.
When you shim the base 1mm you lift both the cylinder and head attached to it 1mm.
That increases the combustion chamber volume by 1 mm. Lowering compression.
If you delete the < 0.5 mm head gasket, you gain back some of what was lost (compression) by decreasing combustion chamber volume, but you are still net lower compression than what you started.
The only way to raise compression in this scenario would be to shave the head by more distance than the spacer width. Like: adding a 1 mm base shim and shaving 1.25 mm from the head.
Then you have decreased the volume of the combustion chamber.
People do that, but I prefer to raise port timing and LOWER compression by shimming the base and deleting the head gasket without shaving the head the same amount as the shim width.
Also, no head gasket = no blown head gasket. Which I find to be a good upgrade for reliability.
Does that make my point clearer? Sometimes I assume what I’m typing will be read a certain way and then get sucker punched by a weird take.
  Smallest part you've added...Topic by: P D P D 08/25/22 08:56AM
  Re: Smallest part you've added...Re: Full Tuck Full Tuck 08/25/22 09:14AM
  Re: Smallest part you've added...Re: CORN PED CORN PED 08/26/22 10:22AM
  Re: Smallest part you've added...Re: Born to be WillD Born to be WillD 08/26/22 04:14PM
  Re: Smallest part you've added...Re: Graham Motzing Graham Motzing 08/25/22 11:11AM
  Re: Smallest part you've added...Re: P D P D 08/25/22 11:38AM
  Re: Smallest part you've added...Re: mower hoarder mower hoarder 08/25/22 11:28AM
  Re: Smallest part you've added...Re: Graham Motzing Graham Motzing 08/25/22 12:46PM
  Re: Smallest part you've added...Re: Thomas TPRF Thomas TPRF 08/25/22 02:04PM
  Re: Smallest part you've added...Re: Born to be WillD Born to be WillD 08/25/22 02:44PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/25/22 09:39PM
  Re: Smallest part you've added...Re: Born to be WillD Born to be WillD 08/26/22 08:24AM
  Re: Smallest part you've added...Re: Stephen Keller Stephen Keller 08/25/22 10:06PM
  Re: Smallest part you've added...Re: James P James P 08/25/22 10:53PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/25/22 11:04PM
  Re: Smallest part you've added...Re: James P James P 08/25/22 11:08PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/26/22 09:41AM
  Re: Smallest part you've added...Re: James P James P 08/26/22 06:43PM
  Re: Smallest part you've added...Re: Jack Rutherford Jack Rutherford 08/25/22 11:29PM
  Re: Smallest part you've added...Re: ID OD ID OD 08/26/22 12:39AM
  Re: Smallest part you've added...Re: Don Ohio Don Ohio 08/26/22 03:38PM
  Re: Smallest part you've added...Re: Stephen Keller Stephen Keller 08/26/22 10:36PM
  Re: Smallest part you've added...Re: operator error 696 420 operator error 696 420 08/26/22 05:53PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/27/22 11:33AM
