That's a pretty large part measured in any other dimension. Also removing your head gasket will raise compression, not lower it. And "bumped up" port timing is not really a good thing unto itself either.... Sure you're putting the exhaust in a *slightly* better position but you're doing harm to the intake port's performance.
Gasket delete ≠ upgrade (edited)
