Re: Smallest part you've added...
James P /
Well, something I do to every cylinder is throw away the head gasket and polish the mating surface. Then make a base shim to bump up timing a bit and lower compression.
That 1-2mm fidget of parts seems to make a big difference.
  Smallest part you've added...Topic by: P D P D 08/25/22 08:56AM
  Re: Smallest part you've added...Re: Full Tuck Full Tuck 08/25/22 09:14AM
  Re: Smallest part you've added...Re: CORN PED CORN PED 08/26/22 10:22AM
  Re: Smallest part you've added...Re: Born to be WillD Born to be WillD 08/26/22 04:14PM
  Re: Smallest part you've added...Re: Graham Motzing Graham Motzing 08/25/22 11:11AM
  Re: Smallest part you've added...Re: P D P D 08/25/22 11:38AM
  Re: Smallest part you've added...Re: mower hoarder mower hoarder 08/25/22 11:28AM
  Re: Smallest part you've added...Re: Graham Motzing Graham Motzing 08/25/22 12:46PM
  Re: Smallest part you've added...Re: Thomas TPRF Thomas TPRF 08/25/22 02:04PM
  Re: Smallest part you've added...Re: Born to be WillD Born to be WillD 08/25/22 02:44PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/25/22 09:39PM
  Re: Smallest part you've added...Re: Born to be WillD Born to be WillD 08/26/22 08:24AM
  Re: Smallest part you've added...Re: Stephen Keller Stephen Keller 08/25/22 10:06PM
  Re: Smallest part you've added...Re: James P James P 08/25/22 10:53PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/25/22 11:04PM
  Re: Smallest part you've added...Re: James P James P 08/25/22 11:08PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/26/22 09:41AM
  Re: Smallest part you've added...Re: James P James P 08/26/22 06:43PM
  Re: Smallest part you've added...Re: Jack Rutherford Jack Rutherford 08/25/22 11:29PM
  Re: Smallest part you've added...Re: ID OD ID OD 08/26/22 12:39AM
  Re: Smallest part you've added...Re: Don Ohio Don Ohio 08/26/22 03:38PM
  Re: Smallest part you've added...Re: Stephen Keller Stephen Keller 08/26/22 10:36PM
  Re: Smallest part you've added...Re: operator error 696 420 operator error 696 420 08/26/22 05:53PM
  Re: Smallest part you've added...Re: Terbo Speghetti Terbo Speghetti 08/27/22 11:33AM
