Re: 78Honda hobbit new carburetor was installed successfully, then
Born to be WillD /
Agreed, sounds like it's just turning over normally and not firing. If it's got fuel which sounds like you've verified (tho I'd check w starter fluid, if it goes on starter fluid and not otherwise that's sure check it's a fuel issue. And spark if you got spark and timing isOK, then youre at compression. Check decomp and check compression, you can loosely gauge it with a thumb over the plug hole, plug out, and it should puff your finger off pretty confidently. If that's all ok, it's bottomed compression, nicks guess is a good one
  78Honda hobbit new carburetor was installed successfully, thenTopic by: Ed H Ed H 08/16/22 11:28AM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/16/22 12:04PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: b to the eff b to the eff 08/16/22 12:06PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Born to be WillD Born to be WillD 08/16/22 12:28PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/16/22 02:37PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Born to be WillD Born to be WillD 08/17/22 10:51AM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: b to the eff b to the eff 08/16/22 02:39PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: pat splat pat splat 08/16/22 03:16PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/16/22 04:22PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: P D P D 08/16/22 07:23PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Beach Club Nick Beach Club Nick 08/16/22 09:31PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: b to the eff b to the eff 08/16/22 07:26PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Jay Rivett Jay Rivett 08/17/22 10:43AM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/17/22 11:12AM
