Re: 78Honda hobbit new carburetor was installed successfully, then
Born to be WillD /
the short burst could be some backup or blowback. it can happen if for example the gas is leaking thru the carb and pooling inside or conversely if it's not got enough fuel (is gas on?) als happens if the spark's erratic and not at the right timing, I'm suspecting tho the new carb is maybe leaking and flooded it, i'd check spark and see if any liquid comes out the pipe or blows out when the plug's out. or maybe just no flow, so you can check the drain bolt under the carb while it's all still assembled.
  78Honda hobbit new carburetor was installed successfully, thenTopic by: Ed H Ed H 08/16/22 11:28AM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/16/22 12:04PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: b to the eff b to the eff 08/16/22 12:06PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Born to be WillD Born to be WillD 08/16/22 12:28PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/16/22 02:37PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Born to be WillD Born to be WillD 08/17/22 10:51AM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: b to the eff b to the eff 08/16/22 02:39PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: pat splat pat splat 08/16/22 03:16PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/16/22 04:22PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: P D P D 08/16/22 07:23PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Beach Club Nick Beach Club Nick 08/16/22 09:31PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: b to the eff b to the eff 08/16/22 07:26PM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Jay Rivett Jay Rivett 08/17/22 10:43AM
  Re: 78Honda hobbit new carburetor was installed successfully, thenRe: Ed H Ed H 08/17/22 11:12AM
