Re: This MF
Graham Motzing /
That's probably your issue, the triple trees aren't lined up correctly. You need to loosen the clamp bolts on the lower triple that holds the forks and then tighten that nut and wiggle everything into it's happy place. Make sure the top triple is coming down square.
Also if your forks are shortened and can bottom out, a few good potholes will knock that nut loose and eventually strip the threads.
