Re: Gadabout fork replacement
Kim Jong illest /
If I remember correctly, I did this once by removing the fork tubes from the yolk by loosening the fork nuts on the sides and unbolting the two top bolts, the slid puch ebr tubes right in there and bolted them in and tightened the side bolts. Brake plate figment wasn't an issue because I put a puch snowflake on but those details you'll have to figure out on your own
