Tomos A35 problems
Robert Phipps /
Does anyone know what it could be on my A35 Tomas it'll be running going fine down the road and all sudden lose all power but it will still be running but it has no throttle response it has nothing
Re: Tomos A35 problems
Dirty carburetor, most likely.
Robert Phipps /
It can't be the carb cause it's completely shutting down then on an back off again is it the stater
Robert Phipps /
It's really pissing me off I been trying to figure everything out on this thing put so much money in to it an now this will some one that knows these things please help
That's exactly what dirty carbs can do .
Still sounds like a dirty carb. Shas are only single jet, if it gets clogged up, it wont run. Check for spark when it dies. If it has spark but won't start. It's fuel or air related.
Robert Phipps /
Well even the electric has been acting up horn works when it wants
That's another issue to sort out. The ignition is separate from other electronics on tomos.
Yellow from stator feeds regulator, which feeds the lights and horn.
Ignition is just the black wire coming out of the stator to the hot lead on the cdi/coil (usually red) which is also connected to the kill switch. The other lead on the cdi/coil (usually brown) is grounded. Check that all those connections are secure.
Cdis usually work when they're good or don't when they go bad. They're not intermittent like a condenser with points ignitions. Unless there's a bad ground or witing short.
Robert Phipps /
Well cleaned it with air as well an it still acting stupid not it's not wanting to start at all an it's does got good spark
Not to sound dumb but you do have fuel in the tank? Could be a clogged fuel filter too. Also make sure there isn’t a loose wire somewhere in the ignition system.
