Re: E50 runs like shit saga
Puch Maxi /
> Dirty30 Dillon wrote:
> The PHBG is not the problem.
I’m running W7, 78 main jet and stock idle jet. Perfect color on spark plug, gapped correctly. Timing is 20 degrees, 0.40mm ping gap. Coil gapped, good compression and blue spark. Tried three different carburetors. Phgb seems to respond good on WOT. No air leak. believe me, there’s no airleak.
Problem seems to be solved for now.
