Re: Does HPI Convert System to 12v?
b to the eff /
> C Looby wrote:
> I dont know if my current converter is working correctly anyway as the
> key and kill switch dont work but the headlight works and shouldnt on 6v
> alone per headlight specs.
Have you checked the actual voltages being generated?
Also, "6vac" and "12vac" systems produce quite a bit higher than that at high rpm. Voltage and frequency go up as rpms increase.
> If I did the HPI I would have to replace my converter but I just wasnt
> sure what that system put out. If its 12vac it sounds like I can
> convert that to 12vdc and SHOULD be able to run a 12v battery/lights/etc
> like in a regular 12v system. (Charging battery might be iffy but we
> shall see)
Yep.
