> Full Tuck wrote:
> technically you can run your LED headlight on AC voltage.
If your LED headlight is not designed to work with AC voltage you will just burn it out faster. Once you get past the reverse breakdown voltage the LED is conducting a ton of current without putting out any light; it'll run much hotter and live less long.
Rectify and regulate for long lasting lights!
