I dont know if my current converter is working correctly anyway as the key and kill switch dont work but the headlight works and shouldnt on 6v alone per headlight specs.
If I did the HPI I would have to replace my converter but I just wasnt sure what that system put out. If its 12vac it sounds like I can convert that to 12vdc and SHOULD be able to run a 12v battery/lights/etc like in a regular 12v system. (Charging battery might be iffy but we shall see)
Im glad I asked though because in my mind I was expecting it to put out 12vdc.
