technically you can run your LED headlight on AC voltage. the headlight will flicker and will probably be noticeable at lower RPMs. but the flick Hz will be determine by RPM, so you just gotta go faster until its faster than the Human eye can detect.
is it a bug? or a safety feature?
can your converter handle 12V AC coming from the light coil? (edited)
