Bigger better tires, on NC50...does my PSI change?
Ryan Biesack /
I just put on a pair of Michelin Street Pilots on my 81' NC50... they are a more robust tire than original 2.25x14 70/90....do I want to follow honda specs on tire pressure, or do I tweak? Cold inflate max is 45 psi on these.
Re: Bigger better tires, on NC50...does my PSI change?
Run 35 psi if it doesn't ride too rough. You don't need as much pressure in front as rear, but you want the tread to stay open so you need good pressure.
