those tomos axles work literally PERFECT in the ebr hydros or stock maxi forks without any filing & are the right length. you can even reuse your axle nuts & washers, too.
but i guess i’ll if you wanna file…go ahead & file. i can’t stop you even if i wanted, but thought of filing the dropouts unevenly & the axle being cocked & the misalignment causing brake plate/caliper spacing issues & uneven loading between stanchions is enough to give me an aneurism. i’d rather let the factory handle alignment things like that.
& again, i know “it’s just mopeds” but it seriously doesn’t have to be. it can be done right. it can be perfect. there’s no need to cop out or pass on any of these “solutions” just because it’s what you’ve done & had “work” in the past (edited)
