Picked up a 79’ QT50 over the weekend. It has an extremely stuck piston. Removed the cylinder head and the piston is about 3/4 down in the cylinder. Stood it upright and let it soak with Marvel Mystery Oil overnight Saturday. Sunday tried beating on the piston with hammer end and no movement. Repeated that process everyday since and no movement.
Tuesday I hit it with map gas for a good 8 minutes then beat on it with the hammer end, still no movement. Let it soak with the Marvel Mystery Oil again overnight.
I ordered a metal hole saw to use as a last resort and just drill the top of the piston off past the rings.
What other tricks can I try to get this thing unstuck?
