Power dynamo 70w version with trail tech reg rec
I’ve recently purchased the power dynamo CDI 70w AC setup for Puch E50 from treatland which comes with a supplied voltage regulator.
I’m curious to know if anyone’s used the trail tech regulator rectifier with this set up.
At the moment I’m running the 150 W trail tech reg/rec With the 12 V Trail tech battery and the treatland 12v light coil on stock points
So far as I can tell I should be able to connect both black wires from the power dynamo to both yellow wires on the trail tech reg/rec.
has anyone else done this with success?
Re: Power dynamo 70w version with trail tech reg rec
I use that rec/reg with the 100W powerdynamo CDI on an e50 and a za50. It is indeed as simple as you suggest.
Thank you very much for the information!
No problem, good luck!
