E3 plug problem
Eric Davenport /
Anyone else seen this happen before?
This had maybe 2 miles on it. I pick it up on my way home from work because it was handy. It said it was a replacement for ngk b6s. Ran great compared to the fouled autolite I had in it. When it went out, it felt like a really fouled plug. I limped it the rest of the way to a gas station half throttle. As a bonus it also somehow fucked my temp sensor.
Running the cheap treats adventure pack cdi with a ngk 5K cap. 1.8ish mm btdc
Re: E3 plug problem
Is that melted, or are those deposits?
If you google "reading a spark plug" or "spark plug deposits" you'll find tons of images showing what various engine problems do to a plug.
Re: E3 plug problem
Eric Davenport /
Melted.
Re: E3 plug problem
Must be running a 1.21GW ignition coil
Re: E3 plug problem
...yes. Detonation. Pull the head off and inspect the piston. Google images.
Re: E3 plug problem
I'm honestly surprised the plug went before the piston crown.
Re: E3 plug problem
Eric Davenport /
So just swapping the plug would have caused detonation? I've put hundreds of miles on this setup already.
Re: E3 plug problem
We've gotten bootleg NGK spark plugs before. All the numbers matched and the reach matched but the operating temps were off. Pointing it out to the selling dealer started a small issue as it was very hard to distinguish the real from the fake. I also hate the computer updated cross compatibility charts as they never seem 100% correct, especially with the more obscure plugs. (edited)
Re: E3 plug problem
Eric Davenport /
Guess just too hot of a plug? It is tiny and got hot enough to start bluing and it melted the connection on my temp gauge.
Re: E3 plug problem
Those e3 plugs are trash, never run them in anything, throw them right in the garbage.
Re: E3 plug problem
campeona del mundo /
> in the garbage.
^^^this
Re: E3 plug problem
Eric Davenport /
> in the garbage.
Lesson learned
Re: E3 plug problem
> > in the garbage.
> ^^^this
agreed. Probably a copy of an already shitty plug. I'll bet the plug melted because of inferior materials and not from detonation. I'd still take the head off and inspect for deposits within.
Re: E3 plug problem
Counterfeit plugs are definitely a thing.
Re: E3 plug problem
Eric Davenport /
Meh
Re: E3 plug problem
... ok, now remove the cylinder and inspect the piston.
Re: E3 plug problem
Eric Davenport /
Check out the tccd reed conversion thread in the performance section
