Re: Next Up on the Bench
Graham Motzing /
It's a tight fit but you can run the Sha on the stock manifold if you use a set screw and lock nut in place of the idle screw.
Or you can waller out the holes and Jimmy the manifold over, or just make a new intake with a handlebar. This isn't the prettiest because I wanted to show how to make an intake by brazing it with a mapp torch, but it works great.
(edited)
  Next Up on the BenchTopic by: Seth B Seth B 11/17/21 06:34PM
  Re: Next Up on the BenchRe: Trent Anderson Trent Anderson 11/17/21 07:22PM
  Re: Next Up on the BenchRe: Stephen Keller Stephen Keller 11/17/21 08:57PM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/17/21 10:11PM
  Re: Next Up on the BenchRe: ID OD ID OD 11/17/21 11:18PM
  Re: Next Up on the BenchRe: Chad Tufts Chad Tufts 11/17/21 11:21PM
  Re: Next Up on the BenchRe: Ted Grant Ted Grant 11/18/21 07:38AM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/18/21 04:34PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/19/21 03:25PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/19/21 03:26PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/19/21 05:03PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/22/21 08:16PM
  Re: Next Up on the BenchRe: P D P D 11/23/21 09:14AM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/23/21 09:26AM
  Re: Next Up on the BenchRe: Seth B Seth B 11/23/21 09:40AM
  Re: Next Up on the BenchRe: Seth B Seth B 11/23/21 09:37AM
  Re: Next Up on the BenchRe: P D P D 11/23/21 10:35AM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/23/21 04:28PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/18/21 08:20AM
  Re: Next Up on the BenchRe: P D P D 11/18/21 10:17AM
  Re: Next Up on the BenchRe: punkrock randy punkrock randy 11/18/21 11:18AM
  Re: Next Up on the BenchRe: Don Ohio Don Ohio 11/18/21 02:58PM
