Re: Next Up on the Bench
P D /
> Seth B wrote:
> This looks much better
> Ah Shit! All was going too well, until I hooked it up and put gas to it.
> Gas leaking from the bowl. So, I cut a new gasket and installed. Still
> leaking. Pulled the carb, and looked at the bottom of the bowl, and I
> saw a few dark spots. Poked with a pick, and they opened up into big
> holes all around. Corroded from the inside. Surprisingly, the tank and
> petcock were clean as a whistle, but the petcock needed a new rubber. I
> cut one of those, and put it back together with new fuel line. At least
> it doesn’t leak.
> Bummer too, because I was ready to fire it up! I cleaned the points and
> replaced the plug. Great spark! That’s two out of three- compression,
> spark, just.need.fuel. So if ya got a float bowl kicking around, hit my
> inbox. I already posted on B&S.
Spray that bowl and the holes out with brake cleaner .
Use flux and solder the holes . ;)
  Next Up on the BenchTopic by: Seth B Seth B 11/17/21 06:34PM
  Re: Next Up on the BenchRe: Trent Anderson Trent Anderson 11/17/21 07:22PM
  Re: Next Up on the BenchRe: Stephen Keller Stephen Keller 11/17/21 08:57PM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/17/21 10:11PM
  Re: Next Up on the BenchRe: ID OD ID OD 11/17/21 11:18PM
  Re: Next Up on the BenchRe: Chad Tufts Chad Tufts 11/17/21 11:21PM
  Re: Next Up on the BenchRe: Ted Grant Ted Grant 11/18/21 07:38AM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/18/21 04:34PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/19/21 03:25PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/19/21 03:26PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/19/21 05:03PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/22/21 08:16PM
  Re: Next Up on the BenchRe: P D P D 11/23/21 09:14AM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/23/21 09:26AM
  Re: Next Up on the BenchRe: Seth B Seth B 11/23/21 09:40AM
  Re: Next Up on the BenchRe: Seth B Seth B 11/23/21 09:37AM
  Re: Next Up on the BenchRe: P D P D 11/23/21 10:35AM
  Re: Next Up on the BenchRe: Graham Motzing Graham Motzing 11/23/21 04:28PM
  Re: Next Up on the BenchRe: Seth B Seth B 11/18/21 08:20AM
  Re: Next Up on the BenchRe: P D P D 11/18/21 10:17AM
  Re: Next Up on the BenchRe: punkrock randy punkrock randy 11/18/21 11:18AM
  Re: Next Up on the BenchRe: Don Ohio Don Ohio 11/18/21 02:58PM
