Re: Motor swap plans for a locked engine jawa
Saabsonettguy . /
The throttle and choke are easy enough, you basically just need a bracket with a hole for a cable adjuster and a knarp. The harder part is going to be mounting the motor and routing power from the clutch, to a gear reduction counter shaft to the rear wheel. I think if you mount the motor upside-down with the clutch on the drive side the rotation should be correct. You could also mount it with the cylinder towards the back which shouldn't really be a problem with a cooling shroud.
  Motor swap plans for a locked engine jawaTopic by: Ian MacKenzie Ian MacKenzie 11/12/21 04:38PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/12/21 04:39PM
  Re: Motor swap plans for a locked engine jawaRe: Saabsonettguy . Saabsonettguy . 11/12/21 05:42PM
  Re: Motor swap plans for a locked engine jawaRe: Graham Motzing Graham Motzing 11/12/21 07:08PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/13/21 04:33PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/13/21 04:29PM
  Re: Motor swap plans for a locked engine jawaRe: Ted Grant Ted Grant 11/12/21 07:47PM
  Re: Motor swap plans for a locked engine jawaRe: Papa _ Papa _ 11/13/21 11:41AM
  Re: Motor swap plans for a locked engine jawaRe: no groms no blasters no groms no blasters 11/13/21 01:19PM
  Re: Motor swap plans for a locked engine jawaRe: Papa _ Papa _ 11/13/21 05:54PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/14/21 02:03AM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/14/21 02:09AM
  Re: Motor swap plans for a locked engine jawaRe: MOPITT no nips Al MOPITT no nips Al 11/14/21 11:24AM
  Re: Motor swap plans for a locked engine jawaRe: Papa _ Papa _ 11/14/21 09:01AM
  Re: Motor swap plans for a locked engine jawaRe: Frank Bailey Frank Bailey 11/14/21 01:27PM
  Re: Motor swap plans for a locked engine jawaRe: MOPITT no nips Al MOPITT no nips Al 11/16/21 11:15AM
  Re: Motor swap plans for a locked engine jawaRe: Papa _ Papa _ 11/14/21 08:35PM
  Re: Motor swap plans for a locked engine jawaRe: Trent Anderson Trent Anderson 11/15/21 11:13PM
  Re: Motor swap plans for a locked engine jawaRe: P D P D 11/16/21 09:32AM
  Re: Motor swap plans for a locked engine jawaRe: Pavel Rehacek Pavel Rehacek 11/17/21 02:01PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/21/21 07:38PM
  Re: Motor swap plans for a locked engine jawaRe: Frank Bailey Frank Bailey 11/21/21 09:35PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/23/21 12:41AM
  Re: Motor swap plans for a locked engine jawaRe: Satan 666 Satan 666 11/21/21 07:50PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/21/21 08:04PM
  Re: Motor swap plans for a locked engine jawaRe: Leo Heyman Leo Heyman 11/23/21 07:27PM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 11/29/21 02:43AM
  Re: Motor swap plans for a locked engine jawaRe: Frank Bailey Frank Bailey 11/29/21 07:26AM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 12/05/21 01:11AM
  Re: Motor swap plans for a locked engine jawaRe: Frank Bailey Frank Bailey 12/05/21 09:12AM
  Re: Motor swap plans for a locked engine jawaRe: Ian MacKenzie Ian MacKenzie 12/06/21 07:49PM
