You can buy a shaft adapter sleeve to put a 3/4 clutch on a 5/8 shaft. Easy peasy. Hardest part is that sometimes the shaft on them is super long and only the end is machined for the pulley, you could put a clutch on a jack shaft or use a Moby clutch pulley too.
