Re: Puch maxi stock piston size is under 49mm?
Graham Motzing /
What spark plug are you running? Needs to be ngk b7hs or similar. If you are running a b7es it's too long and that will cause your problem. If you are running a random off brand plug ditch it and get the right one.
