This is a 6’-3-6’4” rider on a non hydro spring forks/spring suspension magnum II but because of low handlebars he is sitting more forward then stock position
The red magnum XK has same suspension but taller stock length bars so you sit back farther not as cramped.
But a magnum MKII with hydro forks, suspension and stock rise handlebars sits up a bit higher and a bit bigger then both of those spring suspension bikes so it’s a good fit. Get one of these
