NC50 turn signal
Ophelia Wiebe /
i've been trying to get the blinkers on my 1980 NC50 to work with little luck. i've traced the wires by hand/eye and everything should be hooked up correctly. checked the wiring diagram to be sure as well.
my (new) battery has proper voltage, none of the bulbs are burnt out, and the alternator is functioning.
when i hit the left turn signal nothing happens, or the headlight blinks (if its on). the right signal will make the tail light and rear right blinker flash.
this also doesn't happen every time. sometimes when i start the bike no blinkers work, and it will only flash the tail/headlight.
anyone have ideas?
videos of the issue:
