Honda mb5
I recently purchased a honda mb5 with 3000 miles.It had 90 psi of compression so I bought this https://www.treatland.tv/honda-MB5-IMPORT-39mm-50cc-cylinder-kit-p/honda-MB5-IMPORT-39mm-kit.htm?gclid=Cj0KCQjwtrSLBhCLARIsACh6RmhXApasttOj_AknbMK3XpnbtlDJnbbHXkTT8uLg8b_3plM5eoJX_nYaAswsEALw_wcB.With all new gaskets.I assembled it and I am getting 75 psi of compression now i am assuming there is a leak somewhere so i took it apart again and i found this damage on the cases .im not sure what it was caused by or if it was there before installing the new kit.
Does anyone know what may have caused this damage and if i can still run the motor like this.
Thank you
Re: Honda mb5
I don't see the damage you're talking about. Compression happens from the piston rings up once the rings pass the top of the exhaust port.
Re: Honda mb5
Your case might of need to be bored slightly or moded to fit the cylinder sleeve
Re: Honda mb5
I was referring to these ridges
Re: Honda mb5
That^ .
Even if those ridges were damage , they would not effect compression .
Re: Honda mb5
what do you think may have caused those ridges
Re: Honda mb5
> That^ .
He could of bent the skirt a lil or the gasket might not be seated correctly!
U gotta bore the case!!!
This looks bad to
Re: Honda mb5
Dirty30 Dillon /
There's nothing wrong with your cases, they are fine. Those ridges are most likely just poor mill marks.
My guess is just assembly error/missed steps.
Re: Honda mb5
Fuck u
Re: Honda mb5
Dirty30 Dillon /
> Fuck u
Not a single thing you post is useful.
