Re: Flywheel doesn’t come off
pat splat /
Stop b4 u fu. Read a bit about crankshaft threads, mushroomed ends, stripped threads, etc.
Put the nut back on flush w end, grease up small washer to spread load to flat end of crank on end of puller. Pop off w above techniques. Once loose you will have to unscrew puller to remove nut then magneto.
