> Sean Volpe wrote:
> Good to see you got it all up and running. Having lived with my Spree
> for awhile the kickstart has definitely saved me a few times, as I
> recall if you wanted to add kickstart to a Pre-86' bike it was as simple
> as changing the crank case to one with the equipment (86' and later)
> which is readily available be it I'm not sure at what price.
> Another note to make on the Spree was the bystarter is a common weak
> spot on many Honda scooters of the era, thus what I personally did was
> create my own manual choke with a model airplane control cable running
> up to the petcock cover. Otherwise aside from general 2-stroke behavior
> I haven't had many issues with mine in around 1 1/2 years of daily
> driving it.
Thanks Sean, yeah that kickstarter conversion would be ideal. Can’t find a donor though and not much on ebay.
Good idea on the manual choke, might be something I look into at some point. The high idle I noticed is probably when the auto choke shut off the additional air and the air mixture screw was in too far. Need to get it idling for 8-10 minutes or until that auto choke heats up and drops the needle then make the adjustments.
Got the turn signals all working yesterday, front left was no good. Traced it back to a rusty ring connector. Hoping to get the starter issue resolved soon as well. I’ve read that some of the internals from a suzuki lt80 can be used in the mitsuba starters.
