> Stephen Simmons wrote:
> > S C wrote:
> > Tried turning it over with jumper leads directly to battery wires and
> > also directly to the starter wires and no dice. Going to rule out
> > battery.
> > If anyone has ideas on rebuilding this starter or getting a new one
> > that’ll be great. I’ll try the one Stephen has out too.
> > Off chance it could be the bendix but everything with it looks fine.
> > Maybe a stupid question but does the bendix (starter pinion) need
> > pressure from the crankcase side to work? Currently I have it off to
> > work on it and turn over with the drill.
> Yes the belt cover needs to be on for the starter to work correctly. It
> it's not the Bendix will bind.
Tried cranking again with the crankcase cover on and using the battery after slow charging for 5 hours and no dice. Starter must be poopy. Guess Honda realized their mistake in 86 and added the kickstarter.
