Re: 85 Honda Spree
> Stephen Simmons wrote:
> > S C wrote:
> > Tried turning it over with jumper leads directly to battery wires and
> > also directly to the starter wires and no dice. Going to rule out
> > battery.
> > If anyone has ideas on rebuilding this starter or getting a new one
> > that’ll be great. I’ll try the one Stephen has out too.
> > Off chance it could be the bendix but everything with it looks fine.
> > Maybe a stupid question but does the bendix (starter pinion) need
> > pressure from the crankcase side to work? Currently I have it off to
> > work on it and turn over with the drill.
> Yes the belt cover needs to be on for the starter to work correctly. It
> it's not the Bendix will bind.
Ok cool I’ll give that a shot next and see what happens. It does have that binding sound to it. Tried cranking it over and putting pressure on the bendix with a screwdriver earlier but no luck. At that point I probably already had worn the battery down.
I’m sure its going to need some carb tubing as well, let it idle for about ten minutes after cranking with the drill. Idle went way high like an air leak was happening (and probably is but will need to check the crank seals), I never adjusted the air mixture screw either so I’ll have to check that and see. Probably needs to be backed out some. May have turned it all the way in after cleaning the carb.
  85 Honda SpreeTopic by: S C S C 10/11/21 09:50AM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 11:18AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 12:15PM
  Re: 85 Honda SpreeRe: Stephen Keller Stephen Keller 10/11/21 12:37PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 12:42PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/11/21 02:28PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:32PM
  Re: 85 Honda SpreeRe: Chad Tufts Chad Tufts 10/11/21 01:52PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 03:13PM
  Re: 85 Honda SpreeRe: P D P D 10/11/21 04:26PM
  Re: 85 Honda SpreeRe: S C S C 10/11/21 06:35PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/11/21 07:54PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 08:01PM
  Re: 85 Honda SpreeRe: P D P D 10/12/21 08:20PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:15AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 10:47AM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 11:36AM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 12:44PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 01:36PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 03:37PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 07:09PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 07:40PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 08:26PM
  Re: 85 Honda SpreeRe: P D P D 10/13/21 09:04PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/13/21 02:26PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 02:41PM
  Re: 85 Honda SpreeRe: S C S C 10/13/21 09:50PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 12:51PM
  Re: 85 Honda SpreeRe: Kenny Shinneman Kenny Shinneman 10/15/21 12:29AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:54AM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 05:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 06:17PM
  Re: 85 Honda SpreeRe: P D P D 10/15/21 06:41PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/15/21 09:34PM
  Re: 85 Honda SpreeRe: S C S C 10/15/21 07:52PM
  Re: 85 Honda SpreeRe: Luna Moto Luna Moto 10/11/21 04:25PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:16PM
  Re: 85 Honda SpreeRe: Born to be WillD Born to be WillD 10/12/21 12:17PM
  Re: 85 Honda SpreeRe: S C S C 10/12/21 03:08PM
  Re: 85 Honda SpreeRe: Pushrod Fifty Pushrod Fifty 10/12/21 11:23AM
  Re: 85 Honda SpreeRe: punkrock randy punkrock randy 10/13/21 07:25AM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 10/14/21 02:49PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 03:48PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:12PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 04:28PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 04:55PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 05:25PM
  Re: 85 Honda SpreeRe: S C S C 10/14/21 08:03PM
  Re: 85 Honda SpreeRe: P D P D 10/14/21 08:23PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:20AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 09:28AM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 10:02AM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/14/21 09:04PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 03:28PM
  Re: 85 Honda SpreeRe: Stephen Simmons Stephen Simmons 10/16/21 04:12PM
  Re: 85 Honda SpreeRe: S C S C 10/16/21 08:37PM
  Re: 85 Honda SpreeRe: S C S C 10/18/21 09:18PM
  Re: 85 Honda SpreeRe: Sean Volpe Sean Volpe 10/19/21 12:10AM
  Re: 85 Honda SpreeRe: S C S C 10/19/21 06:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:35AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 10/20/21 09:38AM
  Re: 85 Honda SpreeRe: S C S C 10/20/21 02:08PM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 10:33AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 10:58AM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 11:03AM
  Re: 85 Honda SpreeRe: S C S C 11/03/21 03:08PM
  Re: 85 Honda SpreeRe: Pops Peds Pops Peds 11/03/21 09:46PM
  Re: 85 Honda SpreeRe: S C S C 11/06/21 11:04PM
  Re: 85 Honda SpreeRe: Gerry F Gerry F 11/10/21 04:33PM
  Re: 85 Honda SpreeRe: S C S C 11/10/21 06:12PM
  Re: 85 Honda SpreeRe: Satan 666 Satan 666 11/10/21 09:29PM
