> P D wrote:
> > S C wrote:
> > > P D wrote:
> > > Post pics of your starter motor apart . Specially the brushes .
> > Will try, not sure if its possible to open it up or not.
> 2 screws hold the starter together .
> Quit putting it off .
> Tear the thing apart and be sure it's good and not a problem .
> Shouldn't take all that long .
Took the bendix and gear off, cleaned and regreased, removed the rust from the gear. Those all look fine. Removed the starter and took it apart. Cleaned it up with a wire brush and it looks good. Put everything back together, but left the belt undone. Cranked it over and same thing, bendix connects with the gear but doesn’t turn over fast enough.
