> Kenny Shinneman wrote:
> Are you positive you have all the liquid out of the cylinder and
> crankcase? Will the starter turn the engine over with the spark plug and
> oil injector removed? Just making sure before you tear apart the
> starter. Good luck.
Good point, yeah will try that after cleaning out the bendix and gear before getting the starter out. Can also remove the belt and try starting it to isolate that and see if its an issue.
